module12
Dec 13, 2015Apprentice
Snapshots (Windows Previous Versions)
Hey, Just got a RN204 and playing with the snapshot feature. Watching this video suggests you can access snapshots on the ReadyNAS from the Previous Versions tab directly in Windows: https:/...
module12
Dec 16, 2015Apprentice
Yes, I've got allw access to snapshots turned on.
I worked it out anyway. If you re-direct a folder, say Documents to the NAS, previous version tab doesn't work. If you browse to the share via \\nasname\share it works OK.
Wierd...
