super_poussin's avatar
Mar 12, 2009
Some Tricks for apache and The Pro
  • How-to activate compression (mod_deflate)
    put this code in deflate.conf in /etc/frontview/apache/addons/
    LoadModule deflate_module /usr/lib/apache2/modules/mod_deflate.so
    DeflateFilterNote Input instream
    DeflateFilterNote Output outstream
    DeflateFilterNote Ratio ratio
    LogFormat '"%r" %{outstream}n/%{instream}n (%{ratio}n%%)' deflate
    CustomLog /var/log/frontview/deflate_log deflate
    <Location />
    # Insert filter
    SetOutputFilter DEFLATE
    # Netscape 4.x has some problems...
    BrowserMatch ^Mozilla/4 gzip-only-text/html
    # Netscape 4.06-4.08 have some more problems
    BrowserMatch ^Mozilla/4\.0[678] no-gzip
    # MSIE masquerades as Netscape, but it is fine
    # BrowserMatch \bMSIE !no-gzip !gzip-only-text/html
    # NOTE: Due to a bug in mod_setenvif up to Apache 2.0.48
    # the above regex won't work. You can use the following
    # workaround to get the desired effect:
    BrowserMatch \bMSI[E] !no-gzip !gzip-only-text/html
    # Don't compress images
    SetEst
    vIfNoCase Request_URI \
    \.(?:gif|jpe?g|png)$ no-gzip dont-vary
    SetEnvIfNoCase Request_URI \
    \.(?:exe|t?gz|zip|gz2|sit|rar)$ no-gzip dont-vary
    # Make sure proxies don't deliver the wrong content
    Header append Vary User-Agent env=!dont-vary
    </Location>
  • Create a virtual host with authentication
    put this code for example in virtual.conf in /etc/frontview/apache/addons/
    apache will answer on port 8085
    example is extract from my kmotion add-on
    Listen 8085
    <VirtualHost *:8085>
    SSLEngine off
    ServerName kmotion
    ServerAdmin webmaster@localhost
    DocumentRoot /c/webroot/webcam/www_classic
    <Directory /c/webroot/webcam/www_classic>
    Options Indexes FollowSymLinks MultiViews
    AllowOverride None
    Order allow,deny
    allow from all
    </Directory>
    ErrorLog /var/log/apache2/error_kmotion.log
    # Possible values include: debug, info, notice, warn, error, crit,
    LogLevel warn
    CustomLog /var/log/apache2/access_kmotion.log combined
    Alias /camera_select/ /c/webroot/webcam/www_classic/images/camera_select/
    Alias /view_select/ /c/webroot/webcam/www_classic/images/view_select/
    Alias /misc/ /c/webroot/webcam/www_classic/images/misc/
    Alias /function_select/ /c/webroot/webcam/www_classic/images/function_select/
    Alias /images/ /c/webroot/webcam/images/
    <Location />
    AuthName "Restricted"
    AuthType Basic
    AuthBasicProvider external
    AuthExternal pwauth
    require user admin
    </Location>
    #LoadModule authnz_external_module /usr/lib/apache2/modules/mod_authnz_external.so
    #LoadModule auth_sys_group_module /usr/lib/apache2/modules/mod_auth_sys_group.so
    AddExternalAuth pwauth /usr/bin/pwauth
    SetExternalAuthMethod pwauth environment
    </VirtualHost>
  • Reverse Proxy
    put this code for example in reverse.conf in /etc/frontview/apache/addons/
    apache will answer on port 8089
    first virtual host will produce an error 404 because the directory does not exist it's in case the dns name does not exist
    LoadModule proxy_module /usr/lib/apache2/modules/mod_proxy.so
    LoadModule proxy_http_module /usr/lib/apache2/modules/mod_proxy_http.so
    LoadModule proxy_connect_module /usr/lib/apache2/modules/mod_proxy_connect.so
    listen 8089
    NameVirtualHost *:8089
    <VirtualHost *:8089>
    SSLEngine off
    ServerName toto.dnsalias.org
    ServerAlias toto.dnsalias.org
    DocumentRoot /nowhere
    <Location />
    AuthType Basic
    AuthExternal pwauth
    require user admin
    </Location>
    </VirtualHost>
    SSLEngine off
    ServerName cam.toto.dnsalias.org
    ServerAlias cam.toto.dnsalias.org
    ProxyRequests off
    ProxyPass / http://192.168.10.214/
    ProxyPassReverse / http://192.168.10.214/
    <Location />
    AuthType Basic
    AuthExternal pwauth
    require user admin
    </Location>
    </VirtualHost>
    SSLEngine off
    ServerName navigator.toto.dnsalias.org
    ServerAlias navigator.toto.dnsalias.org
    ProxyRequests off
    ProxyPass / http://192.168.10.210/navigator/
    ProxyPassReverse / http://192.168.10.210/navigator/
    <Location />
    AuthType Basic
    AuthExternal pwauth
    require user admin
    </Location>
    </VirtualHost>
  • Hi, I'm running a few different SERVER Apps on a READY NAS PRO.
    I'd appreciate some help with doing the following:
    Our ISP DNS will not let us create a domain name (example: Mailserver.trails.com) and point it to (for example) 192.42.4.1:8080
    I was told that I'd need to create a reverse proxy lookup inside of Apache which is running on our READY NAS server, have it listen for the actual domain name (mailserver.trails.com) and send it to 192.42.4.1:8080.
    Can someone tell me exactly where this file is located, and the actual code needed inside the file to function properly? We don't want to have our team to remember to type http://www.mailserver.trails.com:8080) every time.
    Your help is appreciated.
    P.S. I'm a non technical person, so your explanations in layman's terms is appreciated.
    SetEst
    I'm surprised that no one has mentioned this in the four years since it was posted, but there is a typo in that line. It should be:
ProSupport for Business
