jbuchal
Feb 02, 2019Tutor
Speed of Initial AWS S3 Backup with ReadyNAS
I started a 75Gb backup to Amazon AWS S3 back on 1/26/19, setting it to sync daily, and it is still not done, though it seems to be very slowly adding subfolders. Is this typical performance for clo...
jbuchal
Feb 04, 2019Tutor
Speedtest.net reports 0.33 Mbps
Feb 04, 2019Guru - Experienced User
At that speed a 75 GiB backup would take at least 22 days. That's the best case - assuming that 100% of your internet speed was used to upload the backup 24/7.
Though if the sync was running when you used speedtest, it's possible that your ISP speed is a bit faster than that. Do you know what service you are paying for? Usually the upload/download speeds are also in your ISP bill (or the information in your ISP account).
- jbuchalFeb 04, 2019Tutor
Thanks for the quick reply. I pay $200/month for 20 megs up and 2 down, and now have a repair ticket running with the ISP. The >300 ms ping time isn't helping either, I'm sure.
