ldyork
Apr 08, 2020Tutor
SSD drive replacement for RND2210v2
Is it possible to replace an original 1TB HD drive with a 1 TB SSD drive in this chassis and do I have to replace both at the same time? I see some old notes about compatibility issues but they are ...
- Apr 09, 2020
@Idyork
Using SSDs on Legacy NAS like the RND2210s is possible, the only issue might be is the limitation that it will have on SSD performance. There is no more update available for the Legacy NAS so if SSD was not supported on the previous firmware, there's no update that came out anymore.
One thing is what has been discussed on this post where support for TRIM is not present adn the transfer speed being limited by the CPU.
SSDs might be better of with newer models IMO.
HTH
Marc_V
Apr 09, 2020NETGEAR Employee Retired
@Idyork
HTH
