dthrevan1
Mar 31, 2021Aspirant
SSL Key Host IP Question
Just to clarify the HTTPS ports 1 and 2, the SSL Key Host is that the LAN IP or the WAN IP.? Thanks
dthrevan1
Disregard this post, turns out you use a WAN or a LAN or even a domain. Unfortunately, when it self assigns a SSL cert it's still the same result. The only decent thing is that you can use Port 2 to access Frontview if port 443 is being used e.g. if you have a website using HTTPS.
So for e.g. if you assign Port 2 a port no. 442, and port forward that new port on your router, you can then access frontview in your browser by entering:
or
https://<hostname of readynas>:442/admin
