kunoh
Aug 17, 2014Aspirant
ST2000VN000 on the Duo V1 - thoughts?
I'm upgrading my Duo V1's drives from 1TB to 2TB (raid 1) After doing a bit of research, my decision came down to the ST2000VN000 or the WD20EFRX. (I considered the ST2000DM001, but that seemed to...
kunoh
Aug 20, 2014Aspirant
StephenB wrote: I'm using the WD20EFRX, and haven't had any problems.
Generally failure rates of Seagate consumer drives are higher than Western Digital's, though whether that also applies to the ST2000VN000 is hard to say.
You should check your system for 4K alignment - if you don't have that now, then a factory reset would be needed to get best performance.
-Funny you should say that about Seagate, because the real reason why I'm upgrading is because one of the two drives currently in my Duo V1 is a Seagate - and it failed :(
Anyway, I already bought the disks so I'll just stick with the Seagates for now.
-As for the 4K issues, I've decided to just completely start fresh with a factory default after updating the RAIDiator firmware.
One question:
After updating to the latest firmware (RAIDiator 4.1.13 at the moment), and updating to the latest RAIDar on my PC (4.3.8 ), then all I have to do is put in the two 2tb disks I just bought and the rest is "easy?"
(I do have data waiting to be put back onto the Duo - but that's been backed up already to a seperate external HD)
Thanks again
