kunoh
Aug 17, 2014Aspirant
ST2000VN000 on the Duo V1 - thoughts?
I'm upgrading my Duo V1's drives from 1TB to 2TB (raid 1) After doing a bit of research, my decision came down to the ST2000VN000 or the WD20EFRX. (I considered the ST2000DM001, but that seemed to...
Aug 20, 2014Guru - Experienced User
Yes. Power down the NAS, and put in the new disks. A factory install should automatically happen.
kunoh wrote: After updating to the latest firmware (RAIDiator 4.1.13 at the moment), and updating to the latest RAIDar on my PC (4.3.8 ), then all I have to do is put in the two 2tb disks I just bought and the rest is "easy?"
If you are planning to restore the configuration through frontview, make sure you re-install any addons first you have installed. If you don't, then you will get stuck later on.
As a corollary - if there are add-ons you no longer want, then uninstall them now, and then save the config.
