Lightning01
Nov 21, 2011Follower
ST32000644NS Constellation 2TB 64MB 3GB/s
I have 2 of the ST32000644NS in an Ultra 4. I wanted to buy a third but find that they are discontinued. The likely Seagate replacement looks to be the ST2000NM0011 but it is not on the compatibility list.
So, should I go for a similar spec'd drive from another manufacturer, such as the Western Digital RE4 WD2003FYYS, or go with the new Seagate?
Any advice appreciated.
1 Reply
- mdgm-ntgrNETGEAR Employee RetiredGo with a drive from the compatibility list. Drives not on the compatibility list may/may no work and if you have issues with them support will be denied.
