kidbrother1
Mar 12, 2012Aspirant
STORA drives
I'm planning to upgrade from STORA to ReadyNAS. I'm contemplating re-using the drive from the STORA. Has anyone done this successfully? If so, how did you get the data from the STORA to the R-NAS? ...
mdgm-ntgr
Mar 12, 2012NETGEAR Employee Retired
The disks can be reused but they will need to be wiped (so backup data first). Be sure only to use disks from the ReadyNAS HCL
My advice would probably be to simply buy new disks and transfer the data across your network.
Is the Stora still working?
What disks do you have currently? How much data is stored on the drives?
Which ReadyNAS model do you wish to migrate to?
