kidbrother1
Mar 12, 2012Aspirant
STORA drives
I'm planning to upgrade from STORA to ReadyNAS. I'm contemplating re-using the drive from the STORA. Has anyone done this successfully? If so, how did you get the data from the STORA to the R-NAS? ...
kidbrother1
Mar 13, 2012Aspirant
Thanks, I am looking at the ReadyNAS 4000. I have a single 1TB drive in the Stora and it's working great. Just don't have anywhere else to put all the data on if I pull and reformat the drive.
I think I'll probably just buy new drives to migrate.
mdgm wrote: My advice would probably be to simply buy new disks and transfer the data across your network.
Is the Stora still working?
What disks do you have currently? How much data is stored on the drives?
Which ReadyNAS model do you wish to migrate to?
