Darwin4Ever
Sep 24, 2020Tutor
Strange download behaviour ReadyNas 102 datetime
Since long and even with the latest ReadyOS 6.10.3 I have a persistent problem with my ReadyNas 102 for which I can't find a solution If I WGET from the internet a file (on several Windows versio...
Sep 24, 2020Guru - Experienced User
Darwin4Ever wrote:
If I WGET from the internet a file (on several Windows versions) :
- onto a local drive or another brand of NAS, the file ends up downloaded with the DateTime as available on the internet-server
- when I do eactly the same onto my ReadyNas, the file ends up downloaded with DateTime when downloaded
Are you running WGET on the PC or running it natively on the NAS with SSH? I am suspecting you are running it on the PC (since running WGET natively didn't do this when I tried it).
If it is on the PC, then it is probably related to the SAMBA configuration on the NAS. Not sure what it is exactly - dos filetimes is set to yes in the normal configuration, so wget should be able to set the timestamp to whatever it wants.
If you have a PC that supports NFS, you could try a test using NFS instead of SMB, and see if that changes the behavior.
You could also maybe try mapping the share to a drive letter, and see if using the drive letter path makes a difference.
