aggy
May 02, 2020Aspirant
Strange issue with ReadyNAS Duo v2 RND2000
I have a strange issue with my ReadyNAS Duo v2 (RND2000) as I can no longer access it via Windows or the web browser but I can ping the IP address and it reponds. When I first boot it up RAIDar d...
May 02, 2020Guru - Experienced User
Do you know what firmware it is running?
Also, can you confirm that it says "Duo v2" on the front panel?
The labeling can be confusing - there are a lot of v1 owners who think they have a v2.
aggy wrote:
When I first boot it up RAIDar detects it and sees the disk and says all is OK. After a while RAIDar scan cannot find the NAS drive but I can still ping it.
How can I gain access to my NAS drive again.
Try removing the disk(s) (labeling by slot so you know where they go). Then power up the NAS and see if the RAIDar reports a no-disks status for an extended period.
It'd be best to then test the disk(s) with a Windows PC (seatools for seagate; lifeguard for western digital). You can connect the disk(s) with either SATA or a USB adapter/dock.
If you can't do that (and have two disks in the NAS), then you can try booting the NAS with only one disk, and see if it comes up normally. Start with disk 1 in slot 1 (slot 2 empty), and then try disk 2 in slot 2 (slot 1 empty). If it comes back up, then your top priority is to back up the data on it.
- aggyMay 02, 2020Aspirant
Hi StephenB,
It says ReadyNAS Duo on the front, but the sticker on the bottom says ReadyNAS Duo RND2000 v2.
I think the Firmware is v4.1.6
No LCD on the front. Currently power button (blue light) is flashing and disk light 1 and 2 are on.
RAIDar scan now fails to find anything – it finds the device initially. Ping still replies. Web browser unable to connect.
If I start up with just 1 disk in RAIDar still reports both disks are OK which is clearly incorrect.
Turned firewall off and still unable to connect.
Andrew
- StephenBMay 02, 2020Guru - Experienced User
As I said, the labels are confusing. You have a v1. The sticker means you have hardware revision 2 of a v1.
Note a v2 would be running 5.3.x firmware.
Current firmware is 4.1.16.
Try booting with no disks installed, and see if RAIDar reports a no-disks status.
