aggy
May 02, 2020Aspirant
Strange issue with ReadyNAS Duo v2 RND2000
I have a strange issue with my ReadyNAS Duo v2 (RND2000) as I can no longer access it via Windows or the web browser but I can ping the IP address and it reponds. When I first boot it up RAIDar d...
aggy
Hi StephenB,
It says ReadyNAS Duo on the front, but the sticker on the bottom says ReadyNAS Duo RND2000 v2.
I think the Firmware is v4.1.6
No LCD on the front. Currently power button (blue light) is flashing and disk light 1 and 2 are on.
RAIDar scan now fails to find anything – it finds the device initially. Ping still replies. Web browser unable to connect.
If I start up with just 1 disk in RAIDar still reports both disks are OK which is clearly incorrect.
Turned firewall off and still unable to connect.
Andrew
May 02, 2020Guru - Experienced User
As I said, the labels are confusing. You have a v1. The sticker means you have hardware revision 2 of a v1.
Note a v2 would be running 5.3.x firmware.
Current firmware is 4.1.16.
Try booting with no disks installed, and see if RAIDar reports a no-disks status.
