aggy
May 02, 2020Aspirant
Strange issue with ReadyNAS Duo v2 RND2000
I have a strange issue with my ReadyNAS Duo v2 (RND2000) as I can no longer access it via Windows or the web browser but I can ping the IP address and it reponds. When I first boot it up RAIDar d...
May 17, 2020Guru - Experienced User
cheajack77 wrote:
try with this https://www.windowscentral.com/how-access-files-network-devices-using-smbv1-windows-10
That could be part of the puzzle, but he also doesn't have web access and RAIDar can't find it after startup. That suggests something is wrong with the NAS (either with the chassis or the disks).
aggy
May 17, 2020Aspirant
Thanks for the advice. Now I know I have a V1 RND2000 instead of a V2 i was able to reinstall the correct firmware and get back onto it, so I am back up and running. The SMB v1 issue is a bit of a pain as it is not installed with Windows 10 and is a bit of a security risk. I had only installed it on 1 PC to get access to the NAS. I assume the only way around it is to buy a newer NAS drive?
- StephenBMay 17, 2020Guru - Experienced User
IMO the security risk isn't a big issue on a home network (though opinions on that vary). It's a bigger deal if the PC is also connected to an enterprise network (for instance connected to a VPN if you are working from home).
The only good solution is to get a newer NAS. You can re-purpose the Duo as a backup NAS (using rsync for backup, and disabling SMB altogether on the Duo).
