Retired_Member
Dec 25, 2018Striping granularity of RAID0
Merry x-mas, dear community!
On my RN104 guineapig I have created a RAID0 array and would like to know what chunk size determines the striping granularity. Researching turns out, that "normally...
- Dec 25, 2018
Merry Christmas!
There are a couple of ways to find this:
- It's in the log zip file (mdstat.log).
- # cat //proc/mdstat
- # mdadm --detail /dev/md127
It is set to 64K for RAID-5, so it likely is the same for RAID-0. Let us know what you find out.
Retired_Member
Dec 25, 2018Yup, 64K it is for RAID0, StephenB. For RAID1 it is also 64K, as I can observe.
What is your opinion on the following:
Assume you have a system doing nothing else than streaming HD videos from the concerned volume/share. A backup of all data is conducted on a regular base, of course.
Would it make sense to use RAID0 and a higher chunksize than 64K on that volume to improve the responsiveness of the nas in case lets say multiple people try to watch movies on different clients (sometimes it might even be the same movie)?
And, ...If you would want to go with a higher chunkzise on that volume, though, what would you do to achieve this?
Dec 25, 2018Guru - Experienced User
It's not something I've ever benchmarked, so I can only guess.
In the specific case of streaming video, I think it would depend on the disk i/o read size(s) used by the streaming server. With multiple sequential reads going on simultaneously, the reads likely will end up out of phase automatically (e.g, disk 1's stripe being read for stream 1, with disk 2's stripe being read at about the same time for stream 2).
There is an mdadm command you can try - not sure if it will work:
# mdadm --grow --chunk=128 /dev/md127
would change it to 128KB (if it works).
