bhf1's avatar
bhf1
Stuck in Booting....
Original ower of a mint NV+ RND4210v3 w/ 4 1TB drives from 2009.  Yeah, it's old, but it had been a workhorse, no real issues until now.  When I moved last year, I shut it down, wrapped it in layers ...
  • Sandshark's avatar
    Sandshark
    Feb 01, 2020
    You should try the single drive in each slot test first to see if the problem is in the SATA backplane.  If that works, then it could be a weak power supply, likely the 12V, but check them all..  It's not difficult to get to the internal power connector to measure voltages.  It's a modified ATX configuration.  Pin-out is here: ReadyNAS_PSU_pinout.pdf .  Make your measurements under load, maybe with dioffering numbers of drives.
ProSupport for Business
