jamiebeith's avatar
jamiebeith
Stuck on Boot Menu - Time to toss it and forgo Netgear products in the future?
My 104 fans were going crazy one nice, so I turned it off by pressing the power button and allowing it to gracefully shut down.  I tried to boot it a few days later, and now I get:
1) a flashing power button
2) "Boot Menu" printed on the screen
3) "Normal" added to the screen then I press the Backup button
I think I've had this problem before but don't know how I fixed it.  I also see that's it's a very common problem with this piece of... hardware.
I tried to remove the disks and boot without them - same thing.  I've tried making a USB Recovery tool and booting into that.  It allowed me to boot from USB and seemingly completed the recovery process and turned itself off, but when I booted it again I was back to the "Boot Menu" screen.
Is it time to toss this thing to the curb?  Can I buy a different brand and just slide my drive into it and retain the data?  Can I plug the drives into my computer and retain the data?
  • StephenB's avatar
    You should see a "no disks" status on the display if you power up with no disks inserted.
    If you purchase another OS-6 ReadyNAS, you can migrate the disks to it.  It's a bit easier if you get another RN214, but it will work with other models.  The main issue is that most apps won't migrate, so you'd need to reinstall them.
    • jamiebeith's avatar
      jamiebeith
      Well it definitely doesn't say "No Disks", so I guess I'm screwed?
      It's a shame that the NAS failed before any drive inside failed.  That's pretty unacceptable to me.  I don't want to use Netgear products if this is the quality I should expect.  Is it possible to migrate the data out of the Netgear ecosystem?
      • rn_enthusiast's avatar
        rn_enthusiast
        Virtuoso
        Hi jamiebeith
        Each have their own experience and I don't know for how long you have had this product but my general experience is that Netgear's hardware is of really high quality, compared to the Plastic box you will get with for example Synology. And you get a very decent warranty for free, with your product.
        You can get the data out of the NAS, yes (it requires knowledge though). There is no use of proprietary software to make that RAID work. However, I would echo what StephenB said and suggest upgrade to an RN214 which is a very good unit. It would be super easy to transition, simply swap the disks over > power the new unit on and off you go.
        Cheers
ProSupport for Business
