MrLoutre
Nov 30, 2016Follower
Submit bug issue on 6.6.0
Hi there,
Short message to report a bug.
On AD 2012r2 standard, with firmware 6.6.0. The share it won't be supported for the user with an - in there username.... Share is set on everyone and security too. Netgear won't it. Fixed by removing the '-'
Cya
- JennCNETGEAR Employee Retired
Hello MrLoutre,
Not sure if the character "-" means something in the commands of the NAS.
Did you try this before on the older FW version?
Welcome to the community!
- FramerVNETGEAR Employee Retired
Hi MrLoutre,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
