perbuch
Feb 13, 2024Tutor
Suddenly one night my unit just stopped - cannot start again
Reg.: RND2000v2 (ReadyNAS Duo v2) – Diskless A couple of days ago my unit stopped working, it powered off somehow. Now I cannot start it again using the power button. I have tried taking out the pow...
- Mar 11, 2024
I managed to backup both my 2 TB disks although it was a huge job taking a couple of days. I merged the data from the disks to prepare it for my new NAS Server which will be delivered later this week.
saudade
Mar 05, 2024Apprentice
Here's a pic of the PS from my Duo V1.
Center is +. PS is 60W.
michaelkenward
Mar 05, 2024Guru - Experienced User
That's a good start. I'd start with the suggestion from StephenB that you search for something that claims compatibility with your Netgear device. If you can't find an exact match, anything that says it supports the whole range should work.
Netgear occasionally comes up with something odd, but mostly it sticks to transformers that cover a raft of devices.
