darkavich
Aug 28, 2013Tutor
Suggested quick-start docs
Hey Developers, I recently purchased a 31600 unit. Having no drives in the unit, I added my drives. The system booted and generates a boot drive corruption error. While this is absolutely normal ...
mdgm-ntgr
Aug 28, 2013NETGEAR Employee Retired
If you are running a recent version of ReadyNAS OS and if you had opened RAIDar you would have been prompted to do a factory reset. Though
If the drives you inserted had been blank unformatted disks with no partitions on them the NAS would have automatically done a factory reset. As you did not have blank disks it did not automatically do a factory reset in case you didn't want your disks wiped.
Both the installation guide and the hardware manual already discuss the need to format previously used disks. See http://support.netgear.com/product/ReadyNAS-OS6
