Valpskott
Feb 16, 2012Aspirant
Suggestion for x-raid3
This is a suggestion for a hopefully smarter utilization of disks-arrays of disks of different sizes. Say that I have 3 disks of 1 TB each. I buy a 3 TB disk and put it into the empty slot, after s...
PapaBear1
Feb 20, 2012Apprentice
But, no ReadyNAS will allow you to add a drive that is smaller than the current smallest size in the array. If your smallest is 1TB, then all additional drives must be 1TB or larger. If you feel the need to use a smaller drive such as the 500GB you mentioned after the array has been established with 1TB drives, then you must back up all the data, insert the new smaller drive and perform a factory default. Then restore the data from the backup.
