Radjin
Jun 29, 2019Aspirant
Syncing Time Machine between ReadyNAS units
I use the TimeMachine option in my ReadyNAS 316 to backup my Mac. To create offsite storage my friend also bought a ReadyNAS 316 and we now have exact setups connected through a VPN tunnel. I woulld ...
- Jul 01, 2019
You may have to locate where the sparse bundle is stored and move it to your friend's NAS and backup using rsync, not really sure though if this is the best way. Creating another Timemachine backup might be possible but you have to be connected on the VPN and should not have any interruptions to properly complete the backup
Locate sparse bundle - This is an article on deleting the sparse bundle but it shows how the file is located
HTH
Regards
Marc_V
Jul 01, 2019NETGEAR Employee Retired
HTH
Regards
- RadjinJul 14, 2019Aspirant
After a lot of research on Timemachine files it seems the best option is to create a second session in timemachine, however it will not reacgnize the remote unit. So it appears timemachine won’t work.
