chirpa
Mar 05, 2010Luminary
Tapatalk forum app for iPhone, BlackBerry, Android, Nokia
Support for this application has been added to the ReadyNAS.com forums.
Tapatalk is a mobile forum app for iPhone / Android and soon to be on Blackberry and Nokia. Tapatalk supports all the usual forum functions plus full screen image viewing, image upload, caching (less reload), private messaging, all these features are accessible in just a few simple taps.
Tapatalk for iPhone:
Showing New and Unread Posts:
Full Thread Viewing and Pagination Support:
Reply to Post and Image Upload:
Tapatalk for Android
Total Android Look and Feel
Same feature set as iPhone:
Quickly Reply to a conversation:
Latest and Unread Posts indicator and multi-tabs support:
Check out http://www.tapatalk.com for more information!
- dbott67Guide
chirpa wrote: Dave, how does it look now?
Will check when I get home. FWIW, I'm using an iPod Touch v.3 (I haven't upgraded to iOS 4 yet). - chirpaLuminaryApparently our forum was spitting out some notices that broke the XML pieces. Jayeley on the Tapatalk forums was great in figuring it out and patching it.
- dbott67GuideWorkin' good now!
Sent from my iPod touch using Tapatalk - ahpsi1TutorNice way to read the forum, PM's and the rest work for me on the (borrowed) iTouch. Another reason to get my own I suppose!
- chirpaLuminaryYeah, works well on 3G, cut out all the bandwidth waste, just pure text.
- Nice app but I am getting the same errors when I go into "my posts" and "profile/general". Probably just another XML issue so I look forward to a quick fix.
- Still getting many errors with Tapatalk on here so I opened a thread on their forum...
http://www.tapatalk.com/forum/showthrea ... #post18030
Hopefully they can get it resolved because Tapatalk makes viewing the forum on the go very easy. - chirpaLuminaryYes, I have to perform an update, haven't gotten around to it yet. Will try to do this later tonight after dinner, chirpa be hungry!
This email is to notify you that a newer version of Tapatalk Plugin for your forum system has been released.
Your forum name: ReadyNAS.com
Your forum URL: http://www.readynas.com/forum/ Your forum system: phpBB 3.0.x Your current version: 1.6.3 Latest version: 1.8.0 chirpa wrote: Yes, I have to perform an update, haven't gotten around to it yet. Will try to do this later tonight after dinner, chirpa be hungry! This email is to notify you that a newer version of Tapatalk Plugin for your forum system has been released.
Sounds good. Thanks, no hurry since you only had about 50 product announcements today!
So, what exactly does a chirpa eat? QNAP stew? Synology casserole?- chirpaLuminaryI can't eat QNAP stew, they still are violating GPL.
