Digital999
Nov 14, 2022Luminary
tcp_ack+633 reoccuring error
ReadyNAS 314 system ReadyNAS 626 on the same network and has had no errors The 314 has had three of these errors in past 6 months. Had to hard reset with removal of power -- device did respond...
Nov 14, 2022Guru - Experienced User
Digital999 wrote:
ReadyNAS 314 system
Does the RN314 use link aggregation/bonding?
- Digital999Nov 14, 2022Luminary
No.
Topology is simple one dimensional LAN with clients, router (DHCP server duties) and AP devices, and about 10 fixed IP devices (ReadyNAS units, cameras, etc.)
- StephenBNov 14, 2022Guru - Experienced User
Digital999 wrote:
No.
The tcp_ack+633 is a crash in the NAS software. One possible cause is a failing NIC in the NAS (unfortunately not repairable if that is the case).
I suggest swapping cables with the RN626 just to rule that out (though a failed cable is unlikely). Another thing you can try is switching to the other NIC.
It is something to try.
The issue occurs every two to three months so my initial idea is that cables are not the issue.
NIC failure is a possibility -- I will switch NIC interfaces after the rebuild.
Intermittent hardware failures are a PITA -- no way to actually understand/fix until hard failures start to occur. If it does not work I will repost when the next occurrence happens.
