Paulomor
Oct 26, 2023Aspirant
This site can’t provide a secure connection 192.168.8.121 using unsupported protocol
ReadyNAS NV+ V2 Windows 11 Home Have run RAIDar but couldn't find the NAS. Someone suggested Java which I tried but couldn't get an exe file to run it. After opening som exe files in the bin folder...
Oct 27, 2023Guru - Experienced User
Paulomor wrote:
I get the dashboard type thing but still cannot access the actual drives, just get the error above.
I am a bit confused on your info, as you say are you seeing the dashboard even though you can't connect????
Are you stuggling with Windows File Explorer (or Finder)? Or is the problem with the browser?
What browser are you using?
Are you doing this on a new PC?
When was the last time you tried to access the NAS?
Paulomor
Oct 27, 2023Aspirant
Using chrome, 5 year old laptop. I get the dashboard up but as soon as I try to access the drives by clicking on browse I get the above error. I get a list of the films I have on the hard drive on my smart tv (list but no access) but nothing on my laptop
- StephenBOct 27, 2023Guru - Experienced User
Browsing using Chrome (via the dashboard)?
Or browsing with Windows File Manager????
What firmware is the NAS running?
Have you enabled the SMB/CIFS 1.0 client in the windows settings ("turn windows features on or off").
Can you post a screen shot of the error?
- PaulomorOct 27, 2023Aspirant
Using Chrome, sorry, can only seem to save as rtf as only have wordpad at the moment.
No need for RTF.
With windows, do ctrl-alt-print screen. Then open paint, and enter ctrl-v. Crop out any extraneous areas, and save as a png. You can then attach that here.
