Paulomor
Oct 26, 2023Aspirant
This site can’t provide a secure connection 192.168.8.121 using unsupported protocol
ReadyNAS NV+ V2 Windows 11 Home Have run RAIDar but couldn't find the NAS. Someone suggested Java which I tried but couldn't get an exe file to run it. After opening som exe files in the bin folder...
Paulomor
Oct 27, 2023Aspirant
Using chrome, 5 year old laptop. I get the dashboard up but as soon as I try to access the drives by clicking on browse I get the above error. I get a list of the films I have on the hard drive on my smart tv (list but no access) but nothing on my laptop
Oct 27, 2023Guru - Experienced User
Browsing using Chrome (via the dashboard)?
Or browsing with Windows File Manager????
What firmware is the NAS running?
Have you enabled the SMB/CIFS 1.0 client in the windows settings ("turn windows features on or off").
Can you post a screen shot of the error?
- PaulomorOct 27, 2023Aspirant
Using Chrome, sorry, can only seem to save as rtf as only have wordpad at the moment.
- StephenBOct 27, 2023Guru - Experienced User
No need for RTF.
With windows, do ctrl-alt-print screen. Then open paint, and enter ctrl-v. Crop out any extraneous areas, and save as a png. You can then attach that here.
Hopefully attached
