chathams
Dec 03, 2022Aspirant
Tiff viewer - Is there one?
I'm scanning and then uploading a lot of old photos. I'm saving them as Tiff images. When I view my folders through the web ReadyNAS Admin page, I can see JPEG images, they populate, but the TIFF ...
Sandshark
Dec 04, 2022Sensei
I know for Chrome you need a tiff viewer add-on -- it has no native tiff viewing capability.
- chathamsDec 04, 2022Aspirant
Thanks for the reply.
Unfortunately you have to download each Tiff file to view it using the Tiff viewer.
So, you're saying viewing the files in Safari / Chrome, there's nothing I can install or download that will let the thumbnails of Tiff files appear, just like JPEG files do?
Bummer.
- SamirDDec 09, 2022Prodigyirfanview has a batch conversion mode so you can have a jpg version of the tifs without too much work. I used to use this a lot to manually generate thumbnails for my large photos.
