Alex_CCIM's avatar
Alex_CCIM
Apprentice
Mar 07, 2017
ReadyNAS Surveillance Remote Live Viewer Delay
Hello All,
I am hoping that you can help me with a Surveillance Remote Live View issue that I have had for a couple of years now.   I notice there is a delay in the live video feed.  This delay doesnt exist when I use the IP address access to the camera.  I have 8 operating cameras.  4 cameras are D-Link DSC 5222LB, 4 cameras are D-Link DSC 2330L.  This delay even occurrs when I discconect 7 cameras and only have a single camera in operation.   The delay can range from 6 seconds to 16 seconds.  I would appreciate any help possible on how I can make it actually live (with no delay).
Thank you,
-Alex
  • JennC's avatar
    JennC
    Mar 10, 2017
    Hello Alex_CCIM,
    There are 2 NAS units connected to the same router. Are both configured with ReadyNAS Surveillance to live stream with the camera? If so, can you disable ReadyNAS Surveillance on one of them? Also, try just one LAN connection on the NAS.
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello Alex_CCIM,
    Can you please also send the the model number and firmware version?
    Also, where is the NAS connected? Please describe the network, if the NAS is connected straight to the router or a switch, if the computer you use is wireless, etc.
    • Alex_CCIM's avatar
      Alex_CCIM
      Apprentice
      Hi JennC,
      I appreciate your help.  In response:
      • Q: Can you please also send the the model number and firmware version?: A: RN214, 6.6.1
      • Q: where is the NAS connected?: A; directly to the Nighthawk R8500 Router
      • Q: Please describe the network: A: Nighthawk Router, 3 NASs (RN214, RN202, Buffo LinkStation), 8 cameras, 4 iphones, 2 wifi laptops, 1 wifi desktop, 1 wired desktop, 3 wifi Rokus, wired VOIP phone, wifi printer
      • Q: is NAS is connected straight to the router or a switch: A: NAS connected to router via dual gigabit
      • Q: if the computer you use is wireless: A: Desktop for Surveillance Remote Live View is connected via gigbit ethernet (3 feet from router & NASs)
      I hope this helps.
      Thank you,
      -Alex
      • JennC's avatar
        JennC
        Hello Alex_CCIM,
  • JennC,
    Surveillance is only activated on the RN214. The RN202 doesn't have any apps activated. I am curious, does link aggregation cause problems with remote live viewing?
    -Alex
    • JennC's avatar
      JennC
      Hello Alex_CCIM,
      Can you check please if you get the same problem when you disable bonding and just use one LAN? Is there an LAG support on your router?
        Alex_CCIM
        Apprentice
        Hi JennC,
        In response:
        Q: Can you check please if you get the same problem when you disable bonding and just use one LAN?
        A: The delay went away.
        Q: Is there an LAG support on your router?
        A: Yes.  I have the Netgear Nighthawk R8500.  I have always ran LACP-IEEE 802.3ad.   Is the delay using bonding a design defect with the Surveillance app?.  Bonding is one of the reasons I use this router.
        -Alex
ProSupport for Business
