Alex_CCIM
Mar 07, 2017Apprentice
ReadyNAS Surveillance Remote Live Viewer Delay
Hello All, I am hoping that you can help me with a Surveillance Remote Live View issue that I have had for a couple of years now. I notice there is a delay in the live video feed. This delay d...
- Mar 10, 2017
Hello Alex_CCIM,
There are 2 NAS units connected to the same router. Are both configured with ReadyNAS Surveillance to live stream with the camera? If so, can you disable ReadyNAS Surveillance on one of them? Also, try just one LAN connection on the NAS.
JennC
Mar 09, 2017NETGEAR Employee Retired
Hello Alex_CCIM,
Can you please also send the the model number and firmware version?
Also, where is the NAS connected? Please describe the network, if the NAS is connected straight to the router or a switch, if the computer you use is wireless, etc.
- Alex_CCIMMar 09, 2017Apprentice
Hi JennC,
I appreciate your help. In response:
- Q: Can you please also send the the model number and firmware version?: A: RN214, 6.6.1
- Q: where is the NAS connected?: A; directly to the Nighthawk R8500 Router
- Q: Please describe the network: A: Nighthawk Router, 3 NASs (RN214, RN202, Buffo LinkStation), 8 cameras, 4 iphones, 2 wifi laptops, 1 wifi desktop, 1 wired desktop, 3 wifi Rokus, wired VOIP phone, wifi printer
- Q: is NAS is connected straight to the router or a switch: A: NAS connected to router via dual gigabit
- Q: if the computer you use is wireless: A: Desktop for Surveillance Remote Live View is connected via gigbit ethernet (3 feet from router & NASs)
I hope this helps.
Thank you,
-Alex
- JennCMar 10, 2017NETGEAR Employee Retired
Hello Alex_CCIM,
- Nov 24, 2016Retired_Member
