Alex_CCIM
Mar 07, 2017Apprentice
ReadyNAS Surveillance Remote Live Viewer Delay
Hello All, I am hoping that you can help me with a Surveillance Remote Live View issue that I have had for a couple of years now. I notice there is a delay in the live video feed. This delay d...
- Mar 10, 2017
Hello Alex_CCIM,
There are 2 NAS units connected to the same router. Are both configured with ReadyNAS Surveillance to live stream with the camera? If so, can you disable ReadyNAS Surveillance on one of them? Also, try just one LAN connection on the NAS.
Alex_CCIM
Mar 10, 2017Apprentice
JennC,
Surveillance is only activated on the RN214. The RN202 doesn't have any apps activated. I am curious, does link aggregation cause problems with remote live viewing?
-Alex
-Alex
- JennCMar 10, 2017NETGEAR Employee Retired
Hello Alex_CCIM,
Can you check please if you get the same problem when you disable bonding and just use one LAN? Is there an LAG support on your router?
- Alex_CCIMMar 13, 2017Apprentice
Hi JennC,
In response:
Q: Can you check please if you get the same problem when you disable bonding and just use one LAN?
A: The delay went away.
Q: Is there an LAG support on your router?
A: Yes. I have the Netgear Nighthawk R8500. I have always ran LACP-IEEE 802.3ad. Is the delay using bonding a design defect with the Surveillance app?. Bonding is one of the reasons I use this router.
-Alex
- FramerVMar 13, 2017NETGEAR Employee Retired
Hi Alex_CCIM,
Would you be able to send the logs of the ReadyNAS. I will try to inquire about once I have them.
How do I send all logs to ReadyNAS Community moderators?
- Nov 24, 2016Retired_Member
