Alex_CCIM's avatar
Alex_CCIM
Apprentice
Mar 07, 2017
ReadyNAS Surveillance Remote Live Viewer Delay
Hello All,   I am hoping that you can help me with a Surveillance Remote Live View issue that I have had for a couple of years now.   I notice there is a delay in the live video feed.  This delay d...
  • JennC's avatar
    JennC
    Mar 10, 2017
    Hello Alex_CCIM,
    There are 2 NAS units connected to the same router. Are both configured with ReadyNAS Surveillance to live stream with the camera? If so, can you disable ReadyNAS Surveillance on one of them? Also, try just one LAN connection on the NAS.
ProSupport for Business
