chathams
Dec 03, 2022Aspirant
Tiff viewer - Is there one?
I'm scanning and then uploading a lot of old photos. I'm saving them as Tiff images. When I view my folders through the web ReadyNAS Admin page, I can see JPEG images, they populate, but the TIFF ...
Sandshark
Dec 04, 2022Sensei
I know for Chrome you need a tiff viewer add-on -- it has no native tiff viewing capability.
chathams
Dec 04, 2022Aspirant
Thanks for the reply.
Unfortunately you have to download each Tiff file to view it using the Tiff viewer.
So, you're saying viewing the files in Safari / Chrome, there's nothing I can install or download that will let the thumbnails of Tiff files appear, just like JPEG files do?
Bummer.
- SamirDDec 09, 2022Prodigyirfanview has a batch conversion mode so you can have a jpg version of the tifs without too much work. I used to use this a lot to manually generate thumbnails for my large photos.
