fdullemond
Jun 25, 2009Aspirant
Tip: How to do a ReadyNAS config backup from shell
Hi, Just wanted to let everyone know how to do a config backup outside of frontview, for example in a daily cron... wget --no-check-certificate --http-user=admin --http-passwd=password -O read...
ONESIMUS
Oct 30, 2010Aspirant
Can this be configured to save the backup into a share folder with the ReadyNAS hostname in the filename?
Also can this work with https://127.0.0.1/ instead?
I want to create a script that is generic so I can use it across several ReadyNAS DUO boxes.
Thanks.
Thanks.
