DanEv's avatar
DanEv
Total Volume not being displayed in ReadyNas104
I have just set up a ReadyNas 104 with two 3TB Hard Drives, when watching video guides online I have noticed other users have the total of all disk storage showing up in admin panel eg 6TB or just under. I however only have 2.72TB however both drives are registered and show up as healthy I can click on both to see that they are connected. I haven't yet transfered data over to NAS as I want it all working before. Will this NAS system automatically create duplicates across both drives or do I have to do further backups on other drives?
Hope this makes sense and hope someone out there can help.
  • StephenB's avatar
    DanEv wrote:
    I have just set up a ReadyNas 104 with two 3TB Hard Drives, when watching video guides online I have noticed other users have the total of all disk storage showing up in admin panel eg 6TB or just under. I however only have 2.72TB however both drives are registered and show up as healthy I can click on both to see that they are connected. I haven't yet transfered data over to NAS as I want it all working before. Will this NAS system automatically create duplicates across both drives...
    I am thinking you are running XRAID.  With two disks, XRAID uses RAID-1 (disk mirroring).  So there is automatic redundancy (everything is written twice, once to each disk).  The NAS admin page is displaying TiB, not TB.  1 TB = 1000*1000*1000*1000.  1 TiB=1024*1024*1024*1024.   2.72 TiB is about the same as 3 TB.
    So your set up is normal.
    If you were to add another 3 TB drive, XRAID will switch you to RAID-5 (parity blocks).  Storage will increase to 6 TB (~5.4 TiB).  You still have single-disk redundancy, but the way that works is more complicated.
    Add a 4th 3 TB drive, and the storage increases to 9 TB (still RAID-5).
    DanEv wrote:
    ... or do I have to do further backups on other drives?
     Many people assume that using RAID means they don't need backups.  That is a big mistake, and there are plenty of posts here from people who learned that lesson the hard way.  So you should put a backup plan in place for the NAS.  One way is to get an external USB 3.0 drive, and use that to back up the NAS.  The Web UI has a backup facility you can use.  A UPS is also a good idea. In many cases the data loss began with an unexpected power cut.
    • DanEv's avatar
      DanEv
      Thanks for your help! Would I be better changing the Raid set up or is that the best for my setup. I have external drives that I run from my PC. It is these I am looking to backup onto the NAS olr should I run it the other way, operate from the Nas and Backup to the external?
      How do I access the second drive if data is being mirrored or do I only access that only if I need to retrieve it due to failure!
      Sorry new to NAS was told this would be the best set up as I have had an external drive crash however thought the process was more straight forward than what it has been! Told I just had to plug the drives in and start copying data over and it would work itself out!
      Thanks again for your response
      • mdgm-ntgr's avatar
        mdgm-ntgr
        NETGEAR Employee Retired
        You should stick with this RAID setup. If you need more space you can add an additional disk to the 104 and the volume will expand.
        I would use the NAS as primary storage and backup the external disks.
        You are accessing both disks already. If a disk fails the NAS should continue running with just the other disk(s).
ProSupport for Business
