sigsphotos
Mar 26, 2013Aspirant
Transfer discs from NV+ to 104?
Hi, I currently have an NV+ and I'm thinking of getting a 104.
Will I be able to lift the discs straight from the NV+ and drop them (carefully!) into the 104 without losing my data?
1 Reply
- StephenBGuru - Experienced UserNo. The format and OS are different, so you either need to start with new drives in the NV104 (migrating with Frontview), or otherwise rebuild the data from backup.
