nightfly44
Dec 18, 2025Apprentice
Transfer the hard drive from a failing Readynas 312? Planning for inevitable failure..
I've got a RN312, firmware 6.10.10. I kept extras in case any failed, and I think one is on it's way. It humms a bit louder than the normal (and louder than the others I have), and caused interferenc...
nightfly44
Yes, I've done a quick install on all the spare ones using a 1TB Toshiba drive, using each bay to make sure they work. I do remember reading about the availability of changing the fan, which I can manage. Anyway it was the odd audio noise interference that got me; so I changed the power brick and that seems to have solved the problem for the moment, I was just seeing if anyone had managed switching boxes safely. Thanks!
