crown
Jun 12, 2020Aspirant
Transfer to new NAS (files and settings)
I have a readynas nv+ which I know should be upgraded. Howver, I keep putting off upgrading to a newer unit due to the fear of having to start from scratch. Does anyone have a proceudre for movin...
Sandshark
Jun 12, 2020Sensei
Unfortunately, Netgear provided no means for transferring configurations from legacy NAS to OS6. I believe that to be a big blunder, as it makes migration to another brand as appealing as to a newer ReadyNAS, but I don't work for Netgear.
In short, your hesitation was justified. You do start over. But waiting longer won't change that. If you go with new drives for the new NAS, you can at least set the new one up in parallel with the old and continue to use the old one till you are confident with the set-up of the new. Then, you can relegate the old to backup duty of the new.
bcrown
Thanks for the confirmation. I feel like a visit to Synology may be the solution as I do not need to go through this exercise the next time as well.
- StephenBJun 13, 2020Guru - Experienced User
Netgear has supported direct migration in all OS-6 systems since its introduction in 2013. That includes migration from the arm platforms to the x86 ones. So I don't think this is something you'd run into again.
Though personally I haven't found setting up from scratch to take very long. The RAID build is the longest step, and transferring settings doesn't make that go any faster.
- bcrownJun 13, 2020Aspirant
Thank you for the follow up information.
