Stultis
Dec 02, 2018Aspirant
Trouble setting up FTP on ReadyNAS 102 with Linksys router EA6900
Hello, I am having trouble setting up my ReadyNAS for FTP. I have a Linksys router (EA6900) I am using for WIFI. I have the FTP enabled on the ReadyNAS and can see and use the FTP settings around my ...
Stultis
Dec 14, 2018Aspirant
Hello,
It looks like anytime it encounters a conflict, me trying to delete those files or that share, it turns the system into a read only until after reboot. Then I can backup or move files, other than the handfull it has deemed off limits. Everything I check on those files seems to be just like the other files and folders on the system. It just does not like me trying to delete those specific files. I have tried moving them. It looks like the files have moved to another folder, but when I check after a few minutes they have either moved bock or the system never moved them. Then the system encounters a error and becomes read only until after reboot.
I might just leave those files alone and backup what needs to be backed up and move on to making it ftp ready. I can always try to delete them at a later date.
Dec 14, 2018Guru - Experienced User
Perhaps look in system.log and see if there are any BTRFS errors around the time you tried to do the deletion.
