EPJ's avatar
EPJ
'two raids' ??
Hi All, Am new to this - have got my four bay Nas plus 4x 3Tb drives. But, have not yet had the bottle to set it up! I don't want to get it wrong & perhaps not be able to undo the bad! have gone thr...
  • cpu8088's avatar
    Apr 14, 2016
    i believe u are thinking of 2 x raid 1 volumes
    when start up the nas u may disable x-raid then destroy the volume
    after that highlight first 2 drives and create a new volume called volume1 and select raid 1, then highlight drive 3 and 4 and create a new volume called volume 2 and select raid 1.
    done
ProSupport for Business
