TeknoJnky
Jan 13, 2011Hero
Ultra 4 + 4 gig
working so far Model: ReadyNAS Ultra 4 [X-RAID2] Firmware: RAIDiator 4.2.16-T25 Memory: 3968 MB [DDR2] http://www.newegg.com/Product/Product.a ... 6820220495 Patriot 4GB 200-Pin DDR2 SO-...
TeknoJnky
Dec 03, 2011Hero
Extra ram will help in generally a couple areas;
1) when using alot of addons, will help avoid running into swap file
2) can provide additional read/write cache memory
3) if you run vbox, it will allow you to run either more VM's or provide more ram for them
It does not increase performance, per se, it just helps smooth out performance.
