TeknoJnky
Jan 13, 2011Hero
Ultra 4 + 4 gig
working so far Model: ReadyNAS Ultra 4 [X-RAID2] Firmware: RAIDiator 4.2.16-T25 Memory: 3968 MB [DDR2] http://www.newegg.com/Product/Product.a ... 6820220495 Patriot 4GB 200-Pin DDR2 SO-...
skata
Oct 11, 2012Aspirant
Hello!
I'm about to get an Ultra 4 and I'm thinking about getting 4GB memory to it. I have a few questions:
1) Is there only one memory slot? Can I use 2*2GB?
2) Does anyone know how much the performance depends on the frequency of the memory. That is, 800MHz vs 667MHz. Should I get one with 800MHz? The 800MHz DDR2 SO-DIMM 4GB seem to be so expensive...
3) Does anyone know the statistics of compatible memories? Could I just get the cheapest memory there is and be fairly certain that it will work, or is there a big percentage of memories who are not supported by the Ultra 4?
4) Has anyone tried PSD24G8002S ?
