Impulse007
Jul 23, 2018Aspirant
Ultra 4 Plus - Memory Upgrade
I am still running a Ultra 4 Plus and I'm looking to upgrade the memory from the 1 GB stock. From what little information I can find the Ultra 4 Plus uses DDR2 memory but I'm unclear if the maximum a...
Marc_V
Jul 24, 2018NETGEAR Employee Retired
Hi Impulse007
Here's a thread regarding advice on upgrading Memory.
As mentioned, Ultra 4 plus is not supported anymore so you need to keep the old RAM in case of any issues you may encounter.
Hope this helps!
Regards
