fondy
Jun 26, 2017Tutor
Ultra4 and disk change
Hi This has happened tree times. Disc-2 was dead, took out the disc and replaced it with a new. The Ultra started with resync. When finished, the disc-2 was set to spare and disc-3 was dead. ...
- Jun 26, 2017
Hi,
This is not normal behaviour as you can tell. Are all your disks ok? Paste the latest disk log please if you wouldn't mind.
Thanks
Hopchen
Jun 26, 2017Prodigy
Hi,
Thanks
fondy
Jun 29, 2017Tutor
hi,
see https://community.netgear.com/t5/Using-your-ReadyNAS/Netgear-a-fantastic-product/m-p/1312598#M132988
Regards Paal
