Rickjones80
Feb 26, 2024Tutor
Unable to Install or uninstall apps since 6.10.10 firmware upgrade
Hi I currently have a ReadyNAS 214 device which after updating to firmware version 6.10.10, no longer allows me to install or update apps via the admin page as Netgear have now disabled it I...
- Feb 26, 2024
Any advice would be very much appreciated
You can downgrade back to 6.10.9.
Rickjones80 wrote:
will I be able to install Plex again via SSH for example?
Whether you downgrade or not, you'll also need to make the changes here:
Posts 1 and 37 are particularly relevant.
Once those changes are made, you will be able to install plex from ssh. And if you downgrade, you would also be able to install it from the web ui.
One caveat - Plex likely won't be providing the app for ReadyNAS indefinitely. You should keep a copy of the deb file. Even then you will likely have to install Plex on a different platform at some point in the future. Personally I run the Plex server on a PC, but keep the media files on my ReadyNAS.
Feb 26, 2024Guru - Experienced User
btaroli
Mar 09, 2024Prodigy
I'm SO glad I didn't just auto-update. I saw the mention of the "Apps" change in the release notes and it made me want to check around a bit first.
So what is the overall direction here? Is Netgear closing ROS to apps? Is ROS getting deprecated, such that developers just wouldn't bother with it any more? Seems like it's time for a new NAS platform... but I'm curious whatever anyone knows about what's coming.
I've been quite pleased with this platform, even since before it was with Netgear. It's just sad to see a change like this coming and it makes me wonder what next better option there is.
