Rickjones80
Feb 26, 2024Tutor
Unable to Install or uninstall apps since 6.10.10 firmware upgrade
Hi I currently have a ReadyNAS 214 device which after updating to firmware version 6.10.10, no longer allows me to install or update apps via the admin page as Netgear have now disabled it I...
- Feb 26, 2024
Any advice would be very much appreciated
You can downgrade back to 6.10.9.
Rickjones80 wrote:
will I be able to install Plex again via SSH for example?
Whether you downgrade or not, you'll also need to make the changes here:
Posts 1 and 37 are particularly relevant.
Once those changes are made, you will be able to install plex from ssh. And if you downgrade, you would also be able to install it from the web ui.
One caveat - Plex likely won't be providing the app for ReadyNAS indefinitely. You should keep a copy of the deb file. Even then you will likely have to install Plex on a different platform at some point in the future. Personally I run the Plex server on a PC, but keep the media files on my ReadyNAS.
XrayDoc88
Mar 11, 2024Apprentice
I can't believe this firmware update change! I have invested in two Netgear RN628X NAS devices with very expensive, large hard drives. One NAS has 8 hard drives, the other one 6 hard drives. I use them as my PLEX servers and also to store all of my media, including 3 computer backups. I think it is criminal that Netgear would release firmware that kills significant functionality and not warn people in advance. A brief mention in the release notes is not enough! Why even bother to kill the app functionality? They could have just left the firmware at 6.10.9 and never done any more updates.
I also have never heard that Netgear was letting their NAS business go away.
I would really like to keep updating the PLEX servers for ReadyNAS as long as there are releases. I have downloaded a new release that I couldn't install. Is there a trick to downgrading back to the 6.10.9 firmware? I actually think my last firmware was 6.10.8, not 6.10.9. How can you even downgrade now that the upload option is gone?
Mar 12, 2024Guru - Experienced User
You can manually still downgrade to either 6.10.9 or 6.10.8, as the upload was never used for that.
Either way there are config changes you need with ssh to make to keep apt (and the gui upload) working.
See
- XrayDoc88Mar 12, 2024Apprentice
Thank you StevenB. I've only ever updated the firmware by simply clicking ok. I didn't know you could choose a file manually. I still need some help if possible.
1. Did firmware 6.10.9 even apply to the RN628X? My NAS went from 6.10.8 to 6.10.10. I don't think I simply missed the option to upgrade to 6.10.9.
2. If yes, is 6.10.9 posted anywhere? When I looked at the Intel firmware on the Netgear site, 6.10.8 is the latest one listed.
3. I read posts 1 and 37, but I don't even know what SSH stands for. I thought I was pretty computer savvy, but I apparently have reached my limit. Is there any beginner, hand holding help available?
4. "Personally I run the Plex server on a PC, but keep the media files on my ReadyNAS." I'm intrigued by your statement. I've assumed that the cleanest, most efficient way to host a plex server with NAS media storage would be to install the server on the NAS. This has worked very well for me for a long time. But with Netgear spinning out of control, perhaps your method makes more sense?
5. With your method:
a. Do you use a Windows PLEX server connected to your NAS by ethernet?
b. Do you ever get notified by PLEX of server updates?
c. Is the update process simple and not likely to be killed by Netgear?
d. Could you map two separate ReadyNAS devices to the Windows server? I currently have PLEX server running on both of my ReadyNAS units so I always have a usable backup.
e. Why did you originally choose to go this route instead of just using the NAS PLEX server option?
Thanks.
- StephenBMar 12, 2024Guru - Experienced User
Netgear never pushed out 6.10.9 for any ReadyNAS, but they did release it.
Extract the image file from the zip before manually installing it.
Nothing here, though you might be able to find some guides on the internet.
You can download the two files Sandshark posted in post #37. If you enable ssh in the NAS, you can copy them in to the correct folder using WinSCP on your PC. Set the protocol to SFTP. Set the username to root, and use the NAS admin password.
Do be careful not to move or delete files, as that can mess up the OS. Linux operating system files aren't protected the way they are in Windows..
Yes. The NAS media shares are mapped to drive letters on the PC. Plex metadata libraries are stored on the PC (as usual), but the media files are all on the NAS.
I can see when updates are available when I connect to the server via https, and can use the check for updates feature in the settings.
I don't get emails when updates are available, I do need to check.
Everything is on Windows, so updating doesn't involve the NAS at all. All that is required is that the PC be able to access the media files with SMB.
I could have media files on multiple NAS (and also have some folders on the PC drive).
I could also have multiple plex servers (on different PCs) that access the same mediashares on one NAS.
Some of the considerations:
- My approach allows me to use Windows apps, I am not limited to Linux only.
- While the ReadyNAS performs well as a file server, it isn't the best application server. Memory is limited, the CPUs are faiirly modest, and there is no GPU. All of these limit the performance of Plex.
- There have been several instances of app compatibility issues - with apps needing to be deprecated when ReadyNAS firmware gets updates, and also app updates either not working on the NAS - or worse - crashing the NAS. Running the applications on a PC eliminates any of these risks.
- When you use a NAS as both a file server and an application server, you can easily get locked in - making it hard to upgrade the NAS, since you need to install all the apps and get them working properly on the new device. Since I only depend on SMB working, I can upgrade my applications (and my NAS) at any time, independently from each other. I can also gradually migrate to a new application server (assuming the old one is still working).
- NAS are specialized PCs, and are priced accordingly. Getting a new PC is cheaper than getting the same CPU+GPU performance in a new NAS. And even a mid-range NAS can keep up with an ethernet network, so my NAS are fast enough to deliver good storage for many years (longer than I keep my normal PCs). So upgrading the application performance over time is less expensive.
Downsides:
- Initial cost is likely higher (5 above mainly affects upgrading).
- It also takes more power.
- There are some scenarios where the ethernet speed could affect performance. For instance, if you just add enough disk space to the PC to store your media, some plex functions could run faster than using the NAS - especially if the disks are SSD. Though my main NAS (RN526x) is fast enough to keep up with what I need. I've tested video transcoding speed using the nvidia GPU, and the transcoding runs at about the same speed when the video is on the NAS as it does when it is in a local folder.
Great information StevenB. Thanks for your help. I hope you can bear with me a little bit longer. I'd love to understand a few more things about the PLEX universe and NAS storage. 😉
1. I thought the PLEX metadata libraries were stored and all necessary transcoding of videos was done by the PLEX server, even if located on a NAS. Is this correct?
2. I thought the Xeon processor in my NAS was powerful enough to do any necessary transcoding. But I have experienced problems with streaming 4K video from Home 1 to Home 2 across the internet, even though both homes have gigabit fiber connections. Sometimes the videos can stream fine. Other times there is significant buffering. Sometimes it buffers even if I manually set a lower quality resolution for the transcoding. Do you think this might be caused by the lower processing power of the ReadyNAS?
3. If I switched my setup to one like yours, do you think the improved processing power and memory of my PC might actually do a better job? I build my own high end gaming PCs.
4. When you install the Windows server on a PC, can you still use that PC as a PLEX client? Do you have to install both server and client software?
5. I have ReadyNAS1 backing up to ReadyNAS2 using some Netgear NAS software. I forget what it's called now. Other then that, the only app I use on both ReadyNAS' is the PLEX server. Given that information, do you think I would be better off just leaving both NAS' on firmware 6.10.10 and moving my server to a PC? I do think I could learn or get some local help using SSH to downgrade and make the necessary config changes to go back to pre 6.10.10 if that's your recommendation.
6. You mentioned that you mapped your NAS shares to PC drive letters on your server. Why did you do that, or will just browsing and selecting the NAS folders within the PLEX server software work just as well?
7. Finally, when I currently launch my PLEX client on any Windows PC, I get an automatic notice within the PLEX client if there is either a client or a server update available. I don't get an email. With your setup do you ever get notifications like that?
Again, sorry for so many questions, but Netgear has just complicated my life without warning. We consume a lot of audio and video media and I need to have the best system still working well going forward. 🤔
