Shaner1234
Jun 05, 2019Aspirant
Unable to log into RN104 after FW update
Hello! I’m having trouble accessing my ReadyNAS RN104 after upgrading the FW to 6.10.1. The system boots up normally. I can ping the IP address on my network. I can access the login page, and it ...
- Jun 11, 2019
Maybe try an OS reinstall next. It does a partial reinstall of the operating system, which might repair whatever is wrong. Instructions are on pages 28-29 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/ReadyNAS_%20OS6_Desktop_HM_EN.pdf
It won't affect your data. However, it will
- reset your admin password back to password
- reset the network connection to use DHCP (and no bonding)
- disables volume quota
What other apps are you running on the RN104?
Shaner1234
Jun 10, 2019Aspirant
Thanks again very much for the help!
I've cleared out the plex junk files left behind, and and the old torrent file. I'm down to aobut 30% disk usage.
I can navigate the file system through SSH, and diagnostics come back all good through RAIDar, and I've rebooted a couple times. However, I still can not get the admin page to load. It still hangs on the splash screen after inputing my username and password. Any other ideas I can try? Would There be a real rish of damage if I were to downgrade the firmware via USB?
Jun 11, 2019Guru - Experienced User
- Shaner1234Jun 12, 2019Aspirant
And just like that we are back online! Thanks so much for the help!
