tikitiki
Mar 01, 2019Aspirant
Unexpected Network Error with NAS 102
I have a ReadyNAS 102, R8000 Router and Windows Surface PC - all running the latest OS versions.
I have had my itunes library on my NAS drive for years without any issues until the last few weeks. ...
- Mar 13, 2019
Replaced the router - the problem is now gone
Mar 06, 2019Guru - Experienced User
Ok. So PC->extender->router->NAS fails, and PC->(wireless)->router->NAS also fails.
If you don't use ipv6 in your router (likely you don't), then you should disable ipv6 in the NAS. So try that first, and see if anything changes.
It also might be useful to test PC -> (wireless) -> router -> NAS with the extender turned off.
BTW, are you seeing the failures on both 5 ghz and 2.4 ghz?
tikitiki
Mar 13, 2019Aspirant
