adinb
Jul 04, 2006Aspirant
Unison Support?
I'd like to throw support for Unison (client & server) into the hat. It's cross platform, similar to rsync, but easier to use, and has plenty of F/OSS implementations. Unison might really make mirroring a lot easier with the readynas.
-adin
-adin
- bindertwineAspirantWell, if dpkg is implemented on the readynas (I don't know), you can probably install it easily enough. After radiator 4 is released, I'd be willing to try it myself.
Although it isn't true that running unison locally misses the whole point - after all, you are still achieving file synchronization. It's just a whole lot slower than it ought to be. But better than nothing. - bhoarAspirant
magi wrote: I'll bet that the ReadyNAS can checksum files locally faster than it can stream them over any of its file sharing protocols.
I wouldn't take that bet.
-brendan - magi1Aspirant
Hey Brendan. Ever since you wrote that, I've been wondering if you're right... thinking you probably were, but I wanted to know for sure. So I had a mental note to actually test it, once RAIDiator 4 shipped.
I just finally updated to RAIDiator 4, and (with a not-too-carefully tuned setup, for example I'm using the normal ethernet 1500-byte MTU, not jumbo frames), I get around 25MB/sec reads. Running md5sum locally, I was able to checksum a 700MB file in 27 seconds. Running md5sum against the same file locally on the NAS, it took 67 seconds (barely 10 MB/sec).
So you're right, and I lost the bet: the ReadyNAS can drop packets on the wire a lot faster than it can checksum them with md5sum.
I don't know exactly how rsync computes checksums and whether it's more or less CPU intensive than md5, but in the spirit of things, you win and that makes running rsync/unison on the NAS a lot less attractive, assuming a fast network (if you were running across a slow link, then of course the link becomes the bottleneck instead of the ReadyNAS's CPU and the tables may turn). - IchbinichAspirantIs there anything new on that issue?
I would like to use unison to sync between my computer and my NAS. Is this possible right now? And how can I install unison on the NAS? - super_poussinVirtuosounison can be compiled for readynas but is not really a good soft because soemtimes it goes silly and you must restart the whole sync
- greymont1AspirantThis would also be of great help to me!
If Netgear would add unison support it would be very valuable. - tknasAspirant+1
Definitely very useful! Would be perfect for offsite backups. - pmytehAspirantJust posting the solution in case anyone else finds this thread:
- Download and install the EnableRootSSH and APT add-ons from http://www.readynas.com/?page_id=617
- Log in as root using ssh
apt-get update ; apt-get install unison
And you're done.
HTH,
Tom - ZoominkAspirantHi, this is my first post. I just bought two ReadyNAS NV+ V2 (waiting for HDDs to arrive however..) in order to be able to work at two different places, but sharing the same data. I thought that Replicate would achieve that, but I realized that is more like backing up data remotely. And then I stumbled upon this thread...
Will I be able to use unison on my ARM devices? Has anyone tried it, and were you successful?
I did find a good tutorial of how to do it, if it is possible: http://www.cyberciti.biz/faq/unison-file-synchronizer-tool/
Kind regards,
Andreas - mh5blAspirantHas anyone got this to work on any of the readynas units?
I am looking at 2 way directional sync of NAS boxes in London and Manchester. There are only 2 user at each end.
