StubyDoo
Jan 28, 2019Aspirant
Unsigned Disks ReadyData 516
Hi All, I hope this is the correct place to post. I have a ReadyDATA 516 at work with 1 4Tb signed disk. Having read that after firmware 1.4.4 you can use unsigned disk I bought 3 WD4000FYYZ 4Tb di...
- Jan 31, 2019
Hi StubyDoo,
The fix has been applied already. You should now be able to use the new WD4000FYYZ disks on the RDD516.
JohnCM_S
Jan 29, 2019NETGEAR Employee Retired
Hi StubyDoo,
Welcome to the Community!
That is actually weird that the other 3 WD4000FYYZ are not working. If we can have remote SSH access to your NAS, we may be able to fix the issue. If you are familiar on how to use SSH, you can try enabling enabling the shells on the NAS so we can access the NAS remotely
- StubyDooJan 30, 2019Aspirant
Hi John.
Thanks for this. I have it connected to a PC and SSH is enabled and connecting. How would you like to connect to the PC - TeamViewer?
Regards
Stu
- JohnCM_SJan 31, 2019NETGEAR Employee Retired
Hi StubyDoo,
Yes, TeamViewer will do. You may just PM me the Teamviewer ID and password.
Hi StubyDoo,
- PrincemaxFeb 22, 2019Aspirant
Hi,
I have exactly the same problem with a Seagate ES.3 on a RD516 firmware 1.4.5. Could you please share the details of the fix ?
Thanks.
Max
