dthrevan1
Mar 12, 2021Aspirant
Update cURL on ReadyNas Duo v1?
Hi, Is there anyway to update cURL so TLS 1.2 works on a ReadyNas Duo v1? Thanks
Mar 16, 2021Guru - Experienced User
Marc_V wrote:
Duo v1 has been out for a while and an update might not be possible thru NETGEAR and updating it might be possible only thru SSH but not sure with any issues. Others might have tried updating theirs thru backend.
There is a third-party package to update apache on the v2 NAS (courtesy of WhoCares_ ), but I haven't seen anything for the v1.
dthrevan1
Mar 31, 2021Aspirant
Can you please link the apache update by WhoCares I just got a cheap Duo v2 but even that has outdated OpenSSL and curl
- StephenBMar 31, 2021Guru - Experienced User
Read through the thread - installation of the update seemed a bit rocky for some folks.
- dthrevan1Mar 31, 2021Aspirant
thanks that updated Apache and Frontview connects with TLS 1.2 now, but what about cURL when you are using your NAS to host wordpress it won't even download plugins or connect to the Wordpress API for that matter, just throws TLS errors.
Any chance WhoCares_ will update cURL?
- WhoCares_Mar 31, 2021Mentor
The problem isn't curl in itself but rather the outdated openssl library on the ReadyNAS. I could of course update both and in fact already did with openssl but totally forgot about curl. I'll check and see what I can do. Remind me please if I forget to report back here within the next 24 hours.
